KDDI has annouced their first FFOS phone called the Fx0. It has by far the highest specs of any FFOS phone i’ve seen.
This is the transparent thing? I saw it but I thought someone had stolen a mainboard from the factory or something without a case on. I don’t think I’d like a transparent phone, high specs or not… but I’m glad it exists
The first Firefox OS phone worth buying? It runs Firefox OS, so … no. </phonesnob>
@neuro, not a fan of FireFox OS? I have not used it myself.
Well personally I don’t understand the appeal of firefox phone if you’re using mid-level phone hardware +
Firefox OS is meant to run on low end, and all the apps to my knowlage are HTML5, and thus I don’t think it takes advantage of any of the hardware, so I don’t understand the apeal of anything more then low end devices using it, becuase it doesn’t do much more then it would do on a low end phone?
Look at WebGL, you can use hardware with HTML5.
