Stuart Langridge, Jono Bacon, and special guest star Alan Pope present Bad Voltage, in which intelligence is artificial, snaps are un-ned, and art is what you make it:
- [00:04:00] popey's latest tool is unsnap, which helps you "quickly and easily migrate from using snap for applications to flatpak", and we'll get into how it works and why it exists
- [] AI-generated artwork. Aza Raskin made a very cool AI-generated video for Zia Cora's song "submarines", where he put together a list of text queries and then used AI algorithm Disco Diffusion to generate images as video frames. This sort of AI-generated imagery and art is increasingly common, whether This Person Does Not Exist or This Bench Does Not Exist or National Novel Generation Month or whatever. But what are the wider ramifications of this, for ownership, collaboration, and open source? What are your intuitions in this: is a list of text descriptions of an image really the "source code" for that image? If someone uses the same queries that you did, is their work a derivative work of yours? Would you feel delighted or ripped off if that happened? This is all a new area, and it's evolving very fast: where are the precedents for this sort of collaborative art creation and where should we be drawing inspiration and understanding?
