So, I just constructed this beautiful post, explaining exactly how everything @sil said about Enlightenment on openSUSE was wrong, and, at the tail end, found out where he was right.
First off, @sil was totally right to use the net installer; unless you’re passing out DVDs, its usually a better choice. If you’re installing KDE and/or GNOME, the DVD will do a faster install, since it uses images instead of individual packages, but for everything else, you’re probably downloading stuff you don’t need (See https://en.opensuse.org/Media_layout).
One big difference, though, is that the DVD installer doesn’t change after GM, whereas the net installer always pulls the current sources. So… what’s changed? For one, the DVD installer doesn’t present Enlightenment as a desktop choice:
With updates included, or via the Net installer, it is:
So, I assumed you were seeing what I saw with the DVD installer, and you chose ‘Minimal X Window’ which grants ICEwm (and little else - hence no bloated web browsers), then added Enlightnment packages… which wouldn’t change the desktop setting any more than installing KDE packages on a GNOME desktop would.
I see now, you followed the bouncing ball, and didn’t get what you expected. Clearly, our Enlightenment team has some bugs to fix. Now, I don’t expect you to go fix all that up yourself, but it would be awesome of you to file some bugs at https://bugzilla.opensuse.org about your legitimate issues, so they are brought to the maintainer’s attention.
