One of the things that didn’t get a look in on the show was hardware based storage, and I was interested in what other people thought of/used.
One of the other podcasts I listen to ( Scott Sigler - http://www.scottsigler.com ) recently started using Transporter ( http://www.filetransporter.com/ ) for their syncing needs, which are similar to the BV crew. What’s different here is that you pay a one-off cost for a piece of hardware, which you then sync with to your other devices/storage options. It does mean that all your files are still on your storage (so it’s not “cloud” storage) but if you’re working in multiple locations and transferring a lot of data (a la the BV crew) it’s a lot cheaper than the monthly dropbox costs…
There are other options out there that work similarly, no doubt. Any thoughts/experiences?
