So… I currently use Alwaysdata to host a blog, a RSS reader and some other little stuff.
The problem is I live in Asia, Alwaysdata servers are in Europe, so creating blog posts and uploading pictures on my blog are a bit of a hassle. Plus I’m using a shared hosting solution, which means I pay around 10 USD a month for this, but I think it’s a bit expensive for what I’m doing with it.
I’m now thinking about what I should do:
- Self hosting using my own server
- You own your data
- You can configure the server to match exactly what you need (if I want PHP, Python, PostGreSQL or MySQL, Apache or NginX, etc.)
- Geographically close to me (like, in my living room!) so fast access for me
- A hassle to setup and maintain
- I am not a sysadmin, my config might lead to security leaks
- If my own Itnernet connection stops, I lose access to everything
- Self hosting using a NAS
- You own your data
- Easy to configure and to maintain (it’s a NAS so the data is safer than on a homemade server)
- No real tweaking allowed: you can use the proposed blogging platform for instance, not another one
- Shared hosting
- High availability
- Customer support (seriously, at Alwaysdata they answered all my questions within 20 minutes so far, really impressive!)
- Can be pricey especially if you need specific options (PHP and Python instances, different databases, etc.)
- Using existing publishing platform (i.e. Wordpress.com)
- Super easy to set up
- Very high availability
- Free
- No control on your data
- Limitations (amount of pictures you can post, etc.)
- Absolutely no way to tweak anything, and cannot be used for anything other than publishing articles since this is not a server.
- … something else?
I’ve stumbled upon the IndieHosters project this morning, which is something in between Shared hosting and existing publishing platform, which is cool but means I cannot use it to deploy the tools I would like to.
What do you people think? Any idea or recommendation? I was also looking at Gandi since they recently opened a branch in Taiwan, but their shared hosting is limited to one programming language. I would like to have the possibility to use both PHP (cause a lot of webapps use this) and Python (cause this is what I would like to use for my webapps).
And once again, it would be to host a few little projects, not a huge website with hundreds of thousands of users.
Thanks in advance!
